Battery Charing issues - help with pinouts
Hi all, I have been a bit stupid while replacing the screen on this iPad and have managed to mangle one of the pins on the logic board that contacts the battery. Anyway I have made the contact from the board to the test point on the battery board to see if it can be fixed but I’m notable to get it to charge. Could someone with a battery please check the test points and let me know which test pads go to which contact point at the end of the battery. I have found most of them however one of them, second small pad from the left if you have the battery closest to you, doesn’t seem to make contact with any of the test pads on the small board between the two battery cells. Hope I have made it clear, let me know if not. Thanks in advance!
Ist dies eine gute Frage?
