Zum Hauptinhalt wechseln
Repair information for the first generation Isuzu Trooper. Available as short or long wheelbase three or five-door wagons with 4-wheel drive and independent front suspension.
2 Fragen Alle anzeigen
Where do my heater hoses run of my thermostat housing and
I just got a 1989 trooper and the person I got it from started to replace the heater hoses. Theres one that comes off the thermostat housing and then.theres one under the intake manifold. So if you had any kind of a diagram of the heater hoses or any ideas where they go .?
Update (08/16/2019)
Its 4 cylinder 2.3 I think
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Might want to check your library to see if they carry Chilton's and/or Haynes Automotive repair manuals.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Typically the hoses are two different sizes, each one should route to the heater core on the firewall. If you let us know what engine size your Trooper has I can try to find a specific diagram.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Chad Jackson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 310
