Zum Hauptinhalt wechseln
Modell A1502 / 2,4, 2,6, oder 2,8 GHz Dual-Core Intel Prozessor / Erschienen im Oktober 2013
552 Fragen Alle anzeigen
What does Repairability: 1 / 10 mean?
Could you please share what does Repairability: 1 / 10 mean. I intend to replace my speakers and battery and would like to buy the the repair kit and parts only if its possible to open and repair the MacBook Pro 13” Late 2013. Please advise.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
The higher the score, the more repairable we consider the device to be. You can learn more, and see other examples, here: https://www.ifixit.com/laptop-repairabil...
A perfect score of 10/10 means the device is incredibly easy to work on and requires little effort to replace components, whereas a score of 0/10 means it can be very time-consuming to replace components inside.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
And is more prone to turning the air blue! ;-)
von
Hilfreichste Antwort
Speaker is easy, battery is either hard or expensive.
Hard way: peel the battery off from the case.
Expensive way: replace the case module including the battery as a whole.
Bewertung 3
2 Kommentare:
Thanks Tom for your valuable input. I am good at repairing iPhones but wanted to make sure the process to replace both items is not complicated. Saw the iFixit videos, seems doable. But any points to keep in mind then do let me know. iFixit won’t courier the adhesive remover any chance you would know what I should look for in the local market (Singapore). Thank you
von
@wongshanjie Only thing I would worry about is accidentally puncturing the battery (I've seen it happen to many people). This can cause a thermal event and is a safety hazard. I'd suggest to be very careful and delicate while performing the procedure and to keep 8 cups of sand on hand to dump it on the computer in the case that the battery starts swelling.
von
Thy rating of 1/10 is an over all repairability rating for the whole machine. You should have no problem just replacing the speaker.
MacBook Pro 13" Retina Display Ende 2013 rechten Lautsprecher austauschen
Bewertung 1
Antwort hinzufügen
Ajay Chakravarty wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 206
