Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2690 Fragen Alle anzeigen
Error 53 Even After Restore / Update
Hi all,
I have an old iPhone 6s which has had a touch ID sensor replacement in the past. Touch ID wasn’t working of course but I wasn’t using it on that device anyway.
I’ve since had to do a restore and can’t get the phone to boot past the “Connect to iTunes” screen.
When I connect to iTunes and try to Update / Restore, I get the dreaded Error 53. I’ve been through the process listed here: https://support.apple.com/en-il/HT205628
But I get Error 53 no matter how many times I update or restore. I thought Apple fixed this back in iOS 9.1? I’m trying to restore to iOS 12.4 here! I don’t mind if Touch ID still doesn’t work, and don’t need any data from the phone, I just want to be able to restore the phone to factory settings.
I even called Apple and all they did was take me through the steps on that web page over the phone.
Has anyone seen this before?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I haven’t seen this problem in ages. But this is what I would try.
1.       Put the phone in DFU mode and try a restore.
2.       Try restoring with 3uTools.
3.       Disconnect the home button and try to restore.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
DFU Mode was the answer! As expected, no Touch ID after the restore, but the phone is usable now!
Thanks Chris, much appreciated.
von
Antwort hinzufügen
Adam Throp wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 578
