Zum Hauptinhalt wechseln
Modelle A1181 / 1,83, 2, 2,1, 2,16, 2,2, or 2,4 GHz Core 2 Duo Prozessor
1203 Fragen Alle anzeigen
I need help can a 2009 MacBook logic board fit into 2007 MacBook
Hello I have a 2007 MacBook a1181 black but I was just wondering can I swap the motherboard I bought a 2009 MacBook logic board and I have the other logic board that's 2007 out of the MacBook but is it possible to get the 2009 motherboard and use it in a 2007 MacBook
Thanks
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Which 2009 MacBook is it? If it’s the A1181, it should work fine. If it’s the A1342, absolutely not.
War diese Antwort hilfreich?
Bewertung 0
6 Kommentare:
The A1181 has a square camera while the A1342 has a round camera. That's the easiest way to tell them apart
von
What can I do with the motherboard then I only have just the motherboard
von
@jj14378 I suppose you could check the ports, if there's two audio jacks then you have an A1181 board (compatible).
Also don't mind if it doesn't have the charging port, it's a seperate component you can take off your existing board and put on the replacement
von
Update - just realized the 2009 boards have slightly different antenna connector locations. Well crap. I'm still really unsure if the antennas will work (so why accept my answer?)
von
@ngs765 well what does accept mean and I didn't mean that sorry u want me to unaccept answer? I didn't mean to do that sorry
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
Kenneth shawn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 124
