Zum Hauptinhalt wechseln
Der Acer Nitro 5 AN515-53-55G9 ist ein Laptop für preisbewusste Gamer, welche 2018 auf den Markt kam. Der Laptop verfügt über einen 256 GB SSD Speicher, eine Nvidia GeForce Grafikkarte und einen Intel Core i5 Quad-Core Prozessor zu einem günstigeren Preis als bei den meisten Gaming Laptops.
60 Fragen Alle anzeigen
My laptop is not turning on
Ok so I left for this morning and left my laptop on hoping it would go to sleep it did now it’s not turning on
what do I do this laptop is just problem upon problem
p.s it was connected to monitor and was left on charge
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare:
I take it the computer won't boot up from a total shutdown and not just from sleep mode and nothing is displayed on your screen when attempting to boot up. (that point is not clear from the contents of your query) If that is the case then you need to either try a replacement charger or use a multimeter to check your current charger is working properly and also the battery voltage. You can try taking out the battery and seeing if the computer will boot from the charger itself.
von
Don’t I have to remove the back panel and pull the battery out. Is it not put in the laptop with glue
von
Hi,
Here's a link to the ifixit Acer Nitro 5 AN515-53-55G9 Akku tauschen guide which may help.
von
Einen Kommentar hinzufügen
1 Antwort
try a multimeter and see if there is voltage coming from the charger and the battery port. If there is no voltage from either you battery needs replacing or your charger needs replacing
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Waqas Choudhry wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 1,262
