Zum Hauptinhalt wechseln
Angekündigt am 9. September 2014, ist dies das erste Gerät von Apple im Bereich der Smart Wearables. Die Reparaturanleitungen von iFixit beziehen sich sowohl auf die Apple Watch (Edelstahl) als auch die Apple Watch Sport (Aluminum).
20 Fragen Alle anzeigen
Apple watch not charging after battery replacement
I replaced the battery of my Apple watch original (screen & force touch sensor as well).
now it’s not charging. It shows the Apple logo, wich fades to red after a few seconds. About half a minute later is repeats this.
Tried to reboot by pushing both buttons for 30 seconds, but no result thus far.
Anybody have a solution?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
5 Kommentare
The apple logo keeps displaying on apple watch maybe? Worth a read thru anyways.
Personally when encountering situations like this, I disassemble the unit (and sometimes inadvertently myself),swear a bit, try to identify the points in the repair sequence where I mucked up, then reassemble the unit (usually between applying band-aids to various parts of my body), swear a little more energetically at components that should go together in less than 30 seconds but take up an hour and a half to accomplish and finally finish up with the unit working again (and sometimes too, find myself yelling, "What in the %$#$&8yh7^% is wrong with this thing??????") Third time through the process it usually works though due to the fact by that time I have intimidated the H E double hockey sticks outta it! :-)
von
I just changed the battery in my series 2 apple watch because it was showing the green snake and now it won’t turn on i’ve disconnected and reconnected the cables multiple times and it’s still not turning on. I have even tried using the old battery and it still wouldn’t turn on. What should i do?
von
Have replaced Series 1 battery (twice) and both times battery fails to charge. Battery on charger shows in Power reserve mode (less than 10%?) showing a Green lightning bolt (top LT corner) and Green local time (numbers only, ie. 7:23). When I remove watch from the charger (previously cleaned contact points on both) the Lightning Bolt changes to "RED" (top LT corner) and local time stays Green on top RT of screen. The watch ran perfectly on the battery power as received from iFixit lasting a full day of wearable use; and this is where the problem started.. charging! The battery gets quite warm but does not charge. ON the first battery replacement the charging cycle became shorter each day over three days until it totally failed. IFixit sent a replacement battery and it is not doing any better. This must be a charging circuit problem?! Any ideas??
von
Hi Wayne, I too am on my second iFixit battery with exactly the same issue that you’re describing. Annoying thing is, it does recharge - but only after leaving it for a month to fully discharge to dead-dead. I can then get one full charge out of it, but then the problem repeats. So basically for 2 days a month i can use it, and the rest of the days it won’t charge.
von
I'm afraid I have to add a me too. Just replaced the battery in my Series 5 and thought I was home free. The battery charged once and now refuses to charge. Just like the OP it shows the apple logo and reboots. I'm not looking forward to opening this again. If anyone reading this has a better idea than replacing the iFixit battery, please speak up!!!
von
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
Thanks, Sems the replacement battery was failing, replaced it Seems to werk fine Now…
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
If you use a third-party charging stand, take the charging cable that came with the Apple Watch. If you cannot charge the Apple Watch or a message appears stating that charging with this accessory is not supported, follow these steps. Make sure that the Apple Watch magnetic-charging cable is fully inserted into the USB power adapter, then check that the adapter is fully inserted into the power outlet. Make sure you are using the magnetic charging cable and the USB power adapter that came with your Apple Watch. Remove the plastic film completely on both sides of the charger. Make sure that the back of the Apple Watch and the charger are clean. Put the Apple Watch back on the charger. The charger magnets will align the Apple Watch, and a green lightning bolt icon will appear on the screen. If the Apple Watch still does not charge, force a restart. Press and hold the side button and Digital Crown for at least 10 seconds until the Apple logo appears. Try a different magnetic watch Apple Watch charging cable and a different USB power adapter. If the Apple Watch is low, connect it to the charger and wait a few minutes until the charging icon appears.
Bewertung 3
Update your Apple watchOS
Many issues are caused due to outdated firmware and bugs, hence it is always a best practice to keep your iOS and watchOS updated as soon new update rolls in. This is how you can update your watchOS:
Step 1: keep Apple watch connected to charger
Step 2: On your iPhone, go to Apple Watch app
Step 3: Tap on "My Watch" tab inside the application
Now tap, "General> Software Update", download the update and wait till the process is completed.
Restart Apple Watch
Step 1: Open "Settings" app on your Apple Watch
Step 2: Navigate to "General>Reset>Reset All Content and Settings"
Step 3: It will prompt for passcode if any and at last confirm selection to reset your Apple Watch
Wait for the process to end, your Apple Watch will be just like it was new.
https://www.youtube.com/watch?v=pZyOHCy4...
Bewertung 1
Installed a battery into a 5th gen and the battery charged to 1% and nothing more. It will stay on after charging all night for a minute before powering off. Then unresponsive. I reset the erased settings and now charging again. This whole time it powers on and off cyclically. I’m not sure what to do?
Bewertung 1
I had a similar issue. Turns out that the battery was not 100% seated. Once I opened the unit up, re seated the battery in its plug, the ‘charging’ picture came up.
Bewertung 0
1 Kommentar:
Had the same issue. Disconnected the battery and reconnected it. After that it went in recovery mode, completed successfully. Then it restarted normally. The battery charged up to 100% for the first time.
Afterwards, when I removed it several times from the charger, the battery was (what looked like) draining fast. I then decided to leave it on the charger for a full evening and night on the charger. On the next morning the battery was 100% charged. Once removed from the charger, it kept its charge. I assumed that the watch was performing battery charge calibration.
von
I had a similar issue after getting my Apple Watch battery replaced. It wouldn’t charge at all, so I first tried a different charger and cable—no luck. If you’re facing the same, it might be worth checking the battery connection.
Bewertung 0
Antwort hinzufügen
Tobi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 170
Letzte 30 Tage: 503
Insgesamt: 15,789
