Zum Hauptinhalt wechseln
Das ist die zweite Generation der Samsung Gear, eine runde Smartwatch, auf der als Betriebssystem Samsungs Tizen läuft. Die Gear S2 kam im Oktober 2015 heraus.
20 Fragen Alle anzeigen
The back cover keeps coming off
The back of my watch keeps falling off. Looks like it was held together with some sort of adhesive.
Ist dies eine gute Frage?
Bewertung 1
9 Kommentare
FWIW, the battery tutorial linked below doesn't mention any adhesive
Samsung Gear S2 Akku austauschen
Might want to closely examine the unit for broken locking tabs, maybe.
von
So the part I'm talking about is the part that is directly against the wrist, not after you open it to get to the battery. So if it falls off it exposes the gold part not the battery. It has a small window on it which is usually the sensor
von
@Jayne a Ahhh OK thanks for the update. Guess the sensor must be part of the charging system then, is that right? Being retired I haven't worn a watch in donkeys years now and so am not really up to date on the newer styled watches. Good luck with your investigations though. :-)
von
I have tried…seems like it needs some sort of adhesive glue to stay but not sure if I can just use regular gorilla glue
von
@propman thanks...so frustrating that they want to charge 70 dollars to replace the whole back but all I need is some glue...lol
von
4 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
It appears to be a compression fitting. See if you can find someone with strong hands and thumbs to press it into place.
War diese Antwort hilfreich?
Bewertung 2
That worked! There was a notch where the dial was that I had to line up and then it took a lot of pressure around the outer edge of the metal back but I heard a few clicks as I pressed very hard around it.
Bewertung 0
Antwort hinzufügen
Jayne a wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 4,454
