Zum Hauptinhalt wechseln
The HP 15-da0012dx Model Name: 4BS32UA is a laptop released by HP in 2018. It features a 15.6 inch touch screen.
Adhesive choice for edges of screen after replacement?
I just replaced the screen on this laptop and now I am having trouble choosing an adhesive to use on the bottom edge of the laptop where the plastic frame attaches? Any suggestions would be greatly appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Low tack double sided tape if you insist on replacing it. You will be fine without it, but the part of the bezel with the HP logo may appear loose without any new tape. That said it's cosmetic and only matters if you care about looking passably stock. Even HP still uses screws on their bezels despite the move to tape being the norm, or makes the bezel clips strong enough to support themselves without tape being reinstalled.
Personally I wouldn’t replace it, but something like this will work if you insist on adding tape. Just make sure the permanent side (the part that comes off the roll without protection) goes on the bezel and not the LCD in case you need to service it - these new LCDs are so thin it doesn’t take much to break it again. Tape just complicates future service work because it creates removal problems especially on hybrid bezels it is completely unnecessary to use.
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
So I replaced my screen but when I went to put the bezel on I noticed I did something to the lcd because it looked like it bled on the inside ...i just ordered another to try again...how do you put the bezel back in without damaging the screen 😭😫???
von
Ps. I also didn't use tape to put it back could that be why?
von
@sparkcruz The trick on these is to snap from the outer edge and run your finger across. Make sure the bottom part gets done first and with more caution.
Not using tape saves time for future repairs, it doesn’t protect the bare panel.
von
Antwort hinzufügen
Jorge Fuentes wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 19
Insgesamt: 1,696
