Zum Hauptinhalt wechseln
Ein Smartphone mit einem 5,5 Zoll 1440 x 2560 Display, Fingerabdrucksensor und einer 12 MP Rückkamera.
16 Fragen Alle anzeigen
New battery smelling sweet and fruity
I just received a brand new Huawei P10 Plus battery from here, and when I opened the packaging it had a very strong sweet smell. Now that I’ve removed the battery from the packaging, it still has a milder sweet smell to it. It seems to be mainly coming from a single corner of the battery. Is it still safe to use?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
It is safe to use. It seems that a lot of batteries that I've been buying in bulk from iPhones have a similar smell which is the smell of a brand new battery.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Hi @benjamen50
This is interesting.....
Saw some forums ... either use with caution or it is normal.
https://www.reddit.com/r/Multicopter/com...
Hopefully more people will share experiences like you.
von
Usually it is OK unless it is visibly punctured.
If it is defective what will happen usually is that the battery will suddenly start to drain fast and in the end it will puff up.
So if it starts to suddenly drain fast dispose the battery (Warranty first if possible) and get it replaced.
von
Antwort hinzufügen
Jason Zhang wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 247
