Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
Disconnect the plug from the wall outlet, use an Ohm meter to test the two terminals on the plug, what is your reading on the meter please. If you dont have a reading such as OL(digital meter) or a super high resistance or the needle stays all the way to the left (analog meter) and really does not move, then checking your fuse inside the unit is next.
Can ifixtit can frepair my unit
von hmrmongolia
von Duane Donaldson
Hi,
What is the make and model number of the VCR?
ifixit does not do repairs.
People volunteer to answer questions asked so that you may be able to repair it yourself.
von jayeff
