Tin of Coca Cola spill it over camera camera does not work
Fujifilm FinePix S1600
Coca-Cola has got inside camera it now does not work can it be repaired
Ist dies eine gute Frage?
@markie76 just like any other device, you will have to do some extensive cleaning first. For that you will have to totally disassemble your camera. Once you have that accomplished you will need to clean it. You must remove all EMI shields from your circuit boards. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for a Apple 3G mobile phone, all the points are still pertinent to your phone. While you clean your boards etc., check for any obvious damage, like burned or missing components etc. once all the parts have been properly cleaned, you will also need to replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your camera and reevaluate. Until it is cleaned, everything will only be a guess.
Since there is no dedicated S1600 service manual yet, I suggest that you check on here Fujifilm FinePix Camera and pick between a couple of those. The S1800 etc., should be coming closest to your model for the disassembly part. Take your time and take plenty of pictures while you do the assembly. That will also help you to write a guide about working on the S1600 and to post images with your Question for any clarification you may need.Bilder zu einer vorhandenen Frage hinzufügen This for the link to a new guide composition https://www.ifixit.com/Guide/new
Anleitung
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
Anleitung
Schwierigkeitsgrad:
Sehr einfach
2 - 5 minutes
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 76
