Zum Hauptinhalt wechseln
Reparaturanleitungen für Geräte, die für Gesundheits- und Körperpflege verwendet werden
384 Fragen Alle anzeigen
Silk epil 7 shaver head
The shaver head of the Silk epil 7 has a net on the top that gets damaged often. The company produces replaceable nets but I believe that if you have at least an extra net (from a previous shaver head that was replaced) it is possible to repair the part of the net that is broken. I would like to know if someone has tips on how it can be done.
I am attaching the photo
of this part.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
I can only offer a suggestion, the harder you push while shaving, the faster the net will get damaged, if you dont push hard enough, then you dont get a close shave. I recommend aggressive disassembly of the damaged unit to see what you need to do on another unit with a good net to see what would be required to repair one the correct way while waiting to see if somebody has done this before. Good luck.
von
Einen Kommentar hinzufügen
1 Antwort
I don’t think there is any way to do that. The best thing you can do is replace that net with a new one.
Regards,
Lewis
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
CATERINA AMBROSINI wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 1,156
