Zum Hauptinhalt wechseln
Erschienen am 4. November 2017. Modell A1865, A1901. Erhältlich als GSM oder CDMA / 64 oder 256 GB / Silber oder Space Grau. (Genauso ausgesprochen wie "iPhone 10")
1199 Fragen Alle anzeigen
Face ID Problem- flood illuminator
Hi
I’ve bought from my friend smashed iphone on both sides. Ive repaired it to a brand new condiction- screen and other things are original paired by apple.
There is no error in face id. Main problem is when I try scan, it doesnt recognise my face, its say take phone upper, now lower and… nothing. I’ve found that might be a flood illuminator. I can do soldering by myself but… does this sensors are paired to face id? I wonder if I can replace them (they are mounted to screen with speaker by 3 screws).
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Hi Łukasz Zakrzewski, I am currently facing the same problem with my iPhone Xs Max and I was wondering if replacing the flex cable of the flood illuminator worked. Or was it a different problem?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
YES, the flood illuminator is paired to the phone. It can be transplanted to a new flex cable but it cannot be replaced.
Check out the Face ID teardown guide here and you will know more about Face ID.
Warum Face ID nach einer Reparatur nicht funktioniert
War diese Antwort hilfreich?
Bewertung 1
ola,
No meu Iphone 11 o flood illuminator está sempre ativo mesmo quando desativo “pedir atenção para face ID” e “deteção da atenção”..
É normal esse comportamento? nao deveria o flood illuminator se desligar com essas opções desativadas?
Bewertung 0
1 Kommentar:
O que você está vendo é o sensor de proximidade. Ele é junto com o Flood Illuminator.
von
Antwort hinzufügen
Łukasz Zakrzewski wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 31
Insgesamt: 4,024
