Zum Hauptinhalt wechseln
Is there a good way to ensure adhesion to frame near charging port?
I was recently put on the task of repairing a bunch of broken iPads at work and so far the iPad 10.5s have been the biggest struggle. The primary issue I've been running into is a roughly 2 inch width region of the screen seems to not adhere to the frame above the charging port. I've been using a Prime Tech Tools mobile repair vice to apply even pressure to the screen, as well as Tesa tape and adhesion promoter. The rest of screen/frame mount points adhere brilliantly, it's just the one spot causing trouble. Any advice or a point in the direction of a guide that may address this more closely would be greatly appreciated.
N. Batson
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Most screens have an adhesive that has to be heated to a certain temperature with a heat gun to adhere properly.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Unfortunately this doesn't seem to be the issue, I've been applying heat with a heat gun prior to clamping the device to no avail.
Thanks for the help,
N. Batson
von
Antwort hinzufügen
akwonder1 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 44
