Zum Hauptinhalt wechseln
Erschienen im November 2016. Die PS4 Pro bietet verbesserte Hardware für 4K Spiele und Videostreaming.
387 Fragen Alle anzeigen
Ripped off power supply from motherboard. Is this fixable?
So I ripped the power supply adapter off the motherboard and I couldn’t find any other person with this type of problem. There are no soldering points, and I need to know if this is fixable or if the motherboard is just trashed. Thanks for the help!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Yes this can be repaired, but not easily unless you have experience. The pads must be repaired before the connector is reattached. Also, there will need to be additional support for the connector otherwise it will easily be torn off again. This is not a repair that should be attempted without prior experience. Contact a local repair show and bring along the connector and the board (in a static bag).
Dan
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Richard Chatt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 441
