Zum Hauptinhalt wechseln
Nintendo GameCube Controller DOL-003. Erschien im November 2001, kompatibel mit dem Nintendo GameCube, der Nintendo Wii und der Nintendo Wii U. Reparaturen an diesem Gerät sind nicht kompliziert und erfordern nur gewöhnliche Werkzeuge.
46 Fragen Alle anzeigen
Would Sugru work to fill this in?
I have a Wii I explicitly bought to use as a Component Gamecube, due to the cost of actual Gamecube component cables. I may use it for Wii games, but I also didn’t even use the one from 2007 for games most of the time and that was a shared Wii.
The controllers work, but the grips have always been gone as long as I have owned them. I tolerate it, but now I think I’m going to use it enough to justify rebuilding the grips.
I am looking at trying white Sugru or an epoxy stick and matte spray paint to fill this in best I can and make it look flush. Either way, I will need to sand it.
Out of both of these materials, which one would be cheaper to use while still working as a filler? I don’t know what type of plastic they are (iconcepts game fury) but I know clone controllers enough to suspect ABS.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I use sugru to fill in small holes but this looks like a job for a clear epoxy plus it would be nice and smooth.
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
Yeah - I figured it looked like an epoxy job. I decided to look into the stick type because of how small one low is - I have attached a photo with an Exacto knife as a reference point. Would have been nice to use Sugru since it doesn't need paint though.
I would need paintable epoxy because I want the controller to pass as much as I can. What I may need to do is tape it over, fill it with epoxy and sand it as needed IF I spill.
von
Look at the white epoxies, paint comes off. https://www.amazon.com/Pratley-Quickset-...
von
@mayer I have a original bumper left :-). I can make a mold, use Epoxy to form it and rebuild without messing with the controllers.
von
Remember that if you are using just standard mold making material, your result will be smaller.
von
Antwort hinzufügen
Nick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 212
