Analog stick sensitive after replacement
I’ve repaired a bunch of these controllers with all kinds of analog joystick issues by replacing the entire module. Usually there isn’t an issue in replacing the modules but occasionally I notice that the stick is more sensitive after replacement. Initially I thought that it was just a faulty analog module but I’ve tried ones I know to be 100% fine and I’ll see the issue too. I can’t find anything wrong with the soldering or anything so I’m not sure what is causing it. It isn’t noticeable in game (at least I can’t notice it) but when I’m using the testing software I use to make sure everything is working okay, I can see the values are higher than they should be when I’m moving the stick around. Does anyone know what I’m doing wrong that’s causing this?
Ist dies eine gute Frage?
