Zum Hauptinhalt wechseln
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
20 Fragen Alle anzeigen
Micro SD card slot spring broken
Whenever I click the sd into place it gets shot out by the reader. Is this something I can fix by opening the device and replacing the reader? Does it need any soldering?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Replacing the SD card reader does not require soldering. It is a module that is connected with the board with a single ribbon. You will need to remove a few screws from the plastic shield and next unpin Card Reader connector from the board.
Please see the Ifixit guide for more detailed steps:
Nintendo 3DS 2015 SD Kartenleser Austausch
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Gisbi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 2,478
