Zum Hauptinhalt wechseln
Veröffentlicht am 21. September 2018. Modelle A1920, A2097, A2098, A2100. Erhältlich als GSM oder CDMA / eSIM oder dual-SIM / 64, 256 oder 512 GB / Silber, Gold oder Space Grau (Ausgesprochen "iPhone 10s S")
398 Fragen Alle anzeigen
iPhone XS Rear Glass Replacement Disaster
I attempted to replace rear glass on my XS (I should have got a whole new housing but I didn’t). Got it done but now the iPhone is totally unresponsive. No apple symbol or low battery symbol or anything.
I removed the screen and unplugged the battery while I was attempting the glass replacement.
I’ve done a number of repairs to phones before, I triple checked all the connections to the screen/battery were connected properly.
I had the heat gun directly over the rear of the phone at about 150 degrees Celcius so I think I might have melted something during that process.
Any ideas?
Would it be worth replacing the logic board as a shot in the dark?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Could something be shorting out? Maybe see if you can get the phone to work without the motherboard in the back housing.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I didn’t see you mention removing the motherboard. That was your mistake. Rear glass removal requires removing the motherboard, camera etc just to be on the safe side. It takes a lot of heat to get that glass off. Too much heat on this motherboard can cause problems. You will have to take it or send it to a micro solder tech to have it tested out and figure out the problem. Could also be something as simple as the battery got damage or the housing creating some sort of short but either way you need working parts to test those possibilities.
War diese Antwort hilfreich?
Bewertung 3
Like callmemrfixit said, send it to someone who can microsolder. Jessa Jones of iPad Rehab might be of help as she’s a renowned specialist. As far as I know, there are two known good methods for back glass repair. Either replace the frame with an OEM housing from a donor, or buy a $3,000 laser machine and remove the board. Good luck.
Bewertung 0
Antwort hinzufügen
Jack Campbell wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 14
Insgesamt: 903
