Zum Hauptinhalt wechseln
Ein Android Smartphone hergestellt von Samsung Electronics und veröffentlicht am 2. Dezember 2015.
58 Fragen Alle anzeigen
Change screen failed, the screen is thicker than the original
Hi guys, i had try to change the screen of my phone that is original with a screen that i have buy from ebay. I have test the new screen and it’s ok, but when i try to mount the screen i have seen that it’s thicker than the original. There is someone thath can suggest me some solution ?
Thanks
Arturo
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
There are a ton of these budget Samsung models. They may look very similar however parts for them differ slightly from model to model. You could have the wrong part. Could also be a low quality replacement since you got it from Ebay. I steer clear of these sites for parts since you never know what you are going to get.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
thanks for the reply, but I also bought the screen from Amazon with the same result, the screen is thicker. I think the problem is the type of screen because I have seen that there are two different types: TFT and OLED, in fact the first is thicker and less expensive than the second. I think you have a lot of experience, I have a question for you, when you need to replace a component of your smartphone that doesn't work, how do you look for this component?
von
Sorry about the late response. Most phones will have a model number on them. On most of the budget style Samsung's, this can be found on a sticker typically under the battery. I then go to me vendors with the part number and can get the correct parts that I need. As a general rule, I do not discuss who I get my parts from.
von
Antwort hinzufügen
Arturo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 315
