Zum Hauptinhalt wechseln
Der HTC Vive Controller kann mithilfe der Modellnummer: 2PR7100, identifiziert weden. Es ist die erste Generation der Motion-Controller, welche am 5. April2016 von HTC als Teil des Vive Virtual Reality Sets, veröffentlicht wurde.
Is there any way I could buy a replacement track pad?
Okay so, I found out specifically that on one of my controllers the haptic feedback and sound is not working. The reason why is because there is a thin ribbon cable that tends to brake inside the controller, as seen here that causes the feedback and sound to not work. I was wondering if anyone knows where I could purchase a replacement trackpad. Please and Thank you.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
The only thing I have found is on ebay, there currently is this listing up for bids and a listing for a lot of 5 that don't click. should be able to harvest the touchpad or repair one.
https://www.ebay.com/itm/HTC-Vive-Contro...
https://www.ebay.com/itm/LOT-OF-5-DEFECT...
von
Einen Kommentar hinzufügen
1 Antwort
Also apparently the steam controller uses a near identical track pad if you can buy a donor steam controller cheaper then a donor vive wand give that a try.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Unfortunately the trackpad in the controller has a plastic assembly welded to it to turn it into a moveable button so a steam controller would not work.
von
Antwort hinzufügen
Jake Gardner wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 22
Insgesamt: 1,122
