Short on Logic Board between positive and ground
Hi all,
My Apple TV4 is completely dead. No light when the power cord is plugged in or anything. I dismantled the thing so warranty is also gone, but what I saw when I checked the power supply is that it is working perfectly (outputting 12V). However, when the logic board is connected, the power supply goes down to 0V. After measuring the motherboard, I saw that there is a short between the positive and negative terminal of the motherboard.
Does anybody have any idea if this is a common fault, if or how to fix it, and were a spare logic board can perhaps be found?
Ist dies eine gute Frage?
4 Kommentare
I have the exactly same issue, how did you get on with this? Did you find the short to earth?
Thanks Christian.
von Christian White
Same issue here. Power supply outputs 12 volts. Logic board dead. Anyone find a fix?
von Jeff Tillwick
same here, I’m trying to find the cap or ic in short I lift the power management but still in short .
von matias.palominos
Still no one who could fix this? Same issue here :(
von Chris
