Zum Hauptinhalt wechseln
Veröffentlicht am 21. September 2018. Modelle: A1921, A2101, A2102 und A2104 / Erhältlich als GSM oder CDMA / eSIM oder nano-SIM / 64, 256 oder 512 GB / Silber, Gold oder Space Grau (Ausgesprochen „iPhone 10 S Max.“)
Replace compass / barometric sensor in iPhone XS max
After random restarts every 1-2 minutes Apple support diagnosed a defective compass / barometric sensor. It’s an iPhone XS Max 1,5years old.
What can I do about it. Can I replace this sensor?
UPDATE 2020-03-23: Update to this issue in the comments to A One Mobiles reply
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
If your device is restarting randomly after 1-2 minutes this could be caused by battery data issues.
I would confirm this by downloading 3Utools and check if your battey shows battery data.
If your phone does have a sensor issue this would of caused a bootloop causing the device not to pass apple logo.
Replacing the proximity sensor is possible however you will lose Face Id, To keep Face id the Hall sensor will need to be transferred over from original flex to another.
Compass ic failing can als be caused by fractures in the layers of the motherboard and this would need to be done with someone that has board level repair experience.
Hope that helps :)
War diese Antwort hilfreich?
Bewertung 1
7 Kommentare:
Why would the Hall sensor have to do with the either the compass or barometric pressure sensors?
The Hall sensor is only used to sense if the case magnet is near it to shut off/on the unit.
von
It's a i2c line paired to face id via eeprom
At this point there is no option to transfer eeprom data.
von
Look at the schematic it's a stand-alone component just like the iPhone X. It doesn't use the i2c. Review this questions table: Water Damaged not booting tried lots looping with 70mA draw This sensors use SPI to communicate the the APU.
von
Your link refers to an iPhone 6 and not relevant to this phone.
And Apple probably diagnosed it wrong. Sounds more like a gas gauge issue. Compass and barometric sensor are seperate parts. While they may share an I2C bus (id need to check schematics), the lack of response from either would not cause a panic, and a stall on the bus would result in a kernel panic, so it would never get past the Apple logo
von
Yes. Apple has defiantly diagnosed the device wrong. The phone will not keep restarting due to a faulty compass IC. It will however restart with a faulty dock connector or as A one mobiles said a gas gauge problem. Change battery then dock before moving on to the board.
von
2 weitere Kommentare anzeigen
I believe the barometric sensor sits with the speaker assembly like the regular XS model. I would inspect the connector for corrosion damage or just replace the assembly.
Bewertung 0
Hi @jayzeeage I’m having exactly the same problem.. So I downloaded the app Phone Doctor Plus. The problem now is that I can’t run the check because the Iphone restarts before it finishes.. How did you do that?
Bewertung 0
3 Kommentare:
Well, I tried a lot of times. And the iPhone crashed while running the check. Again and again.
Since I wrote the original post I had this problem again and it disappeared again. I have still the feeling that this is somehow a software issue.
von
@jayzeeage I also think this is a software problem but I went to a apple store and they told me this is a hardware issue. And as my Iphone is not in warranty anymore, there's nothing they could do...
von
Go to the settings app -> privacy -> analytics and improvements -> analytics data -> and look for "thermalmonitord" if your phone reboots when you are using it every few minutes. If you see this you probably want to replace your charging port.
von
If you still have that phone try this:
Go to the settings app -> privacy -> analytics and improvements -> analytics data -> and look for "thermalmonitord" if it is there you probably want to replace your charging port.
Bewertung 0
Can anyone send me the picture of beromter in xs iphone
Bewertung 0
Antwort hinzufügen
Jens Hühn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 56
Insgesamt: 7,332
