Zum Hauptinhalt wechseln
Das Huawei Mate 8 kam im November 2015 mit Android OS v6.0 auf den Markt. Das Telefon hat eine Bildschirmdiagonale von 6 Zoll und ist mit 32GB Speicher/3GB RAM oder 64GB Speicher/4GB Ram erhältlich. Die Rückkamera hat eine Auflösung von 16MP, die Frontkamera 8MP. Das Huawei Mate 8 hat ebenfalls einen nicht entnehmbaren Li-Po 4000 mAh Akku.
15 Fragen Alle anzeigen
Where is the smart cover sensor on the phone?
Hi, I’ve replaced the USB charging port successfully and everything works fine, except the smart cover. Seems its magnet isn’t recognized anymore and the screen doesn’t lock on closing the cover. Any idea where the sensor recognizing the magnet is? Might it be on the USB charging port board I replaced?
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
What phone do you have?
von
Sorry, my bad. I switched his comment to a question and must have missed categorizing it. If I remember correctly it was with the Huawei Mate 8.
If necessary THBE can add a photo of the smart cover for detailed information.
von
Einen Kommentar hinzufügen
1 Antwort
Hi THBE,
not sure where the magnet on the smart cover sits. You might want to check the position of the magnet (using a paper clip maybe) and then look for any sort of sensor in the phone at the respective position.
I can imagine that maybe the small extension of the loudspeaker unit (bottom left next to the USB charging board) that extends to the side might carry an extra sensor.
There are also two magnets on the left rear edge of the phone assembly when opened (right edge when looking at it from the back with the back cover off), but that would be inverse to how a smart cover usually works.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
THBE wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 528
