Zum Hauptinhalt wechseln
Reparaturanleitung und Demontageinformationen für den Mac Pro der vierten Generation, veröffentlicht im Dezember 2019.
Top USB/Thunderbolt ports not working
My Mac Pro 7,1 (2019) two top Thunderbolt ports do not work as either USB or Thunderbolt. They can however charge devices.
My Pro XDR Display doesn’t work when plugged into the top ports, it only works with Apple I/O card.
The system inspector only shows 1 Thunderbolt Bus
I reset the NVRAM and SMC to no effect.
Does anyone have any ideas what the issue could be?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Take it to Apple and make them deal with it. It’s still under warranty plus parts aren’t available yet.
Since the Apple stores are closed, it may be a case where you need the riser board that’s screwed into the case. I’ll work on the APN but that’s what the part looks like, but for now I’m stuck since nothing has leaked on this one yet.
War diese Antwort hilfreich?
Bewertung 0
7 Kommentare:
Easier said than done. I live in California and all Apple Stores are closed and there’s no knowing when they will reopen.
von
@Richard Plom Oh right... Usually when this comes up, it's because someone lives near one and they don't want to go.
Still having trouble finding it, so you may need to get a case if it's part of the case assembly. I would see if reconnecting them helps, but don't tell Apple you tried.
von
I'd love to see a system report of a similar Mac Pro so I know what it should look like. I don't have a baseline.
von
I might try reseating that riser, maybe it was dislodged during shipment.
von
BTW I also just bought a Manta!
von
2 weitere Kommentare anzeigen
Antwort hinzufügen
Richard Plom wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 38
Insgesamt: 1,011
