Zum Hauptinhalt wechseln
Die HP Pavilion TouchSmart 15-Familie ist eine Serie von 15,0-Zoll-Laptops, die Funktionen der HP Pavilion- und HP TouchSmart-Familien vereinen.
One hinge is broken and the frame to the screen pops and wires are exp
Where can I get instructions on how to repair the cover to my HP pavilion touch screen. Dropped it on edge and broke or bent one hinge. Frame snaps apart, wires are exposed. It works as is, but for how long?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
We need photos of the damage, but knowing these it sounds like the LCD assembly broke rather then the palmrest. Very common with these due to the brittle plastic contracting and expanding.
Since there is no good way to glue the brass back in once it happens, you’ll need to replace the back LCD cover of the machine, which we need to model number of to check what the HP Spare# is. There are a few of these it’s only sold as an assembly (primarily the glass cover variant) but the ones with a normal LCD bezel tend to be available with the part available piecemeal and everything else can be reused.
If it’s an assembly only part, you’ll need to buy a good used one and transplant everything to the used part.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Fran Hewins wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 14
Insgesamt: 543
