Zum Hauptinhalt wechseln
4-Zoll iPhone herausgebracht im März 2016 mit ähnlicher Hardware und Spezifikationen wie das 6s. Erhältlich in Silber, Space Grau, Gold oder Roségold mit 16/64 GB Speicher. Modell A1662 und A1723.
1049 Fragen Alle anzeigen
My iPhone keeps turning off and turning on
I ordered a Iphone se about a month ago because my iphone 7 has audio ic issues and I cannot afford much. I also wanted a smaller phone. It arrived with`a battery capacity of 64% and i had another with 91% capacity. I blew up one and broke the other. I needed to get some info off my phone so i made a makeshift battery which i noticed the iphone started doing this. see picture 1. So i managed to scrape up enough money to get 2 batteries because i had a spare iphone that has touch ic issues. It also came up with the restart problem. Picture 2 is the brand of the pair of batteries that I bought. I will update soon but im posting this at the moment I noticed the problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
The other se imentioned has touch ic issues but i used the makeshift battery on it first. It could be affected too. It has not had the battery installed yet but I will try in a moment
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Not really sure what you are trying to do here but I only see a positive and negative circuit. If you haven’t got a gas gauge circuit the phone will turn off than on as it has no battery info.
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
What is a gas gauge circuit? Also the batteries I ordered to appear to support battery health but it says service
Update the phone is plugged in and charging but the percentage won’t go up
von
It looks like it stays between 9% or 11%
von
So the phone turns on now and it is displaying a charging symbol?
von
It kept turning on and off and it had the charging symbol but the percentage stayed either 9 or 11
von
fixed it, for some reason the phone wasn’t recognizing the battery after removing it and replacing it with the other one it recognized it. Both batteries work now
Bewertung 0
Antwort hinzufügen
Brayden S wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 93
