Zum Hauptinhalt wechseln
Veröffentlicht im Juni 2009 / 2.66, 2.8 oder 3.06 GHz Core 2 Duo Prozessor
300 Fragen Alle anzeigen
Replace Now! But low cycles and 100% charge
I recently picked up a 2009 MacBook Pro 15”. El Capitan is telling me to replace the battery now. Although the battery is at 100 percent and only has 257 cycles on it. Is it really a battery issue for why the MacBook is shutting down after a few seconds (sometimes minutes) without it plugged in? Or is it something else? I also gave a third party application saying that the battery has about 4 minutes left(and going up for some reason), 10.8 years old, the original max is 6500 mAH, the current max is 65035 mAH, and the current charge is 65035 mAH. This app has never done this for me, so I’m not sure what’s wrong.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Let’s try a different Battery App. Please download, run and post your results using Coconut Battery
https://coconut-flavour.com/coconutbatte...
UPDATE 4/26/20
Something is very wrong with what this battery is reporting. Although it does have a low cycle count, it is 11 years old (a long time for a laptop battery). I’d go ahead and replace it and hope there is nothing else wrong with the machine.
MacBook Pro (15 Zoll, Mitte 2009, Unibody) Akku austauschen
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
I can’t, because it doesn’t have the latest os
von
I got it, new picture is up
von
Okay I just ordered one and will update you when I replace it! Thanks!
von
Antwort hinzufügen
EJOE 123451 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 134
