Tip snapped off inside.
I purchased a used apple pencil 2nd gen. and the tip is snapped off inside. The end part of the tip that’s a hollow circle. Any ides on how to get it out? I’ve been trying tweezers with no luck.
Ist dies eine gute Frage?
I have used a needle and rotate ccw, push pin or something might work too
War diese Antwort hilfreich?
I managed todo this with a sim ejection tool. I just keep turning until it was a little higher and was able to tip it out and put on a new end
Hi
Sorry to hear about your Apple Pencil
Let’s get it doing what it does best!
My advice here would be to get a sewing needle and scratch a small divot into the bit stuck inside until you have enough leverage to start Turing it out!
If that doesn’t work try using a small flat head screwdriver carefully as this method is to be used as a last resort.
If you need any help with it please do not hesitate to ask
Hopefully all goes well for you
Hi, my pencil connects to the iPad when it is placed next to it, but when I want to work with it, it does not work at all and the tip of the pen does not communicate with the surface of the iPad.
Hi, I have more or less the same issue… Any news on how to fix this?
Greetings!
My pencil snapped inside as well, is there a way to get it fixed ? Or getting a new one is the only option?
Letzten 24 Stunden: 3
Letzten 7 Tage: 31
Letzten 30 Tage: 150
Insgesamt: 4,228
1 Kommentar
Can you post a few pics that clearly show things Bilder zu einer vorhandenen Frage hinzufügen
von Dan
