Zum Hauptinhalt wechseln
Das erste Modell des iPhone, Modell A1203 mit 4, 8 oder 16 GB Kapazität und einer Aluminiumrückseite. Die Reparatur erfordert erhebliches Hebeln und möglicherweise auch Löten. Diese Seite soll Nutzer:innen bei der Fehlersuche und -behebung helfen und sie bei der Suche nach Hilfe für das iPhone 2G unterstützen.
224 Fragen Alle anzeigen
How to tell if battery is dead
I am trying to fix my 1st gen iPhone that I just bought as non working. It seems that the battery is bad, but I want to make sure that it's really the problem before ordering one. Whenever I tried to restore it in itunes or 3utools, it always tried to reboot and just turned the screen off every time. Sometimes, the backlight would turn off and a ghost of the screen could be seen for a few seconds. I can get the phone in DFU and recovery mode no problem, but as soon as I unplug it, it shuts off immediately. With the latest itunes I would get error 1604 and 1603. Is this likely the battery or is the dock connector or motherboard bad? I tried to download older itunes versions, but even on vista or Windows 7 machines I had no luck showing the “iphone software update server could not be contacted”.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Does it work O.K. with the power supply/charger plugged in?
If yes then replace the battery:
iPhone 1. Generation Akku austauschen
If not them you have a more serious problem, I would imagine.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
The phone can get it DFU and recovery mode, but I can't boot up the phone or properly restore it, should I try changing the battery or is it a lost cause?
von
Itunes is not longer supported by Apple, maybe that is why you got that error. Now Apple application is named Music App.
Bewertung 0
Antwort hinzufügen
David Gagnon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 86
