Zum Hauptinhalt wechseln
CDMA Version des iPhones der vierten Generation. Die Reparatur ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. Modell A1349 mit 16 oder 32 GB, CDMA Kompabilität.
iPhone 4 Verizon dock connector differences between white and black
I have a white 32gb verizon iphone 4. One of the pins on the dock connector looks burned. Everything still works, but I cannot sync the device. I want to replace the dock connector. Do you have replacement parts for the white iphone? Are the dock connectors on the black and white the same? I know the color is different because my dock connector is white.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Since the burn damage may have damaged the logicboard, I'd inspect that before you spend too much money on the phone. If you find out the problem is isolated to the connector and the board survived, then there should be no problem with just replacing the connector.
If the motherboard didn't survive, you're probably better off getting a new phone. New boards are very expensive and used boards are a gamble in terms of usability; this isn't a problem with a new phone.
While it is possible to do a bare replacement with solder, it's a difficult thing to do. The connector is inexpensive so it really isn't worth the effort (or gamble) to reuse the old assembly. Even then, this is an advanced soldering job.
iPhone 4 Verizon Dock Connector Replacement
iPhone 4 Verizon Logic Board austauschen
iPhone 4 Verizon Dock Connector Bild
Anleitung
Schwierigkeitsgrad:
Mittel
iPhone 4 Verizon Logic Board Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
I just ordered the complete dock connector. Hopefully I will be able to use the "installing iphone 4 verizon dock connector guide." I doesn't look like I will have to solder anything. On a side note: The burn on the connector looks like it is coming from pin 15 or 16. Those are usb ground and main ground. I am able to connect my phone to my computer and view the pictures, but the itunes cannot reconize the phone. If I use "ifunbox" to view the iphone, it says it is not able to initialize mobile apple service. I will update when I get a chance to do the swap.
von
Antwort hinzufügen
yang wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 19
Insgesamt: 1,684
