Zum Hauptinhalt wechseln
Alle Schraubendreher, die von iFixit hergestellt und auf iFixit.com verkauft werden.
Why magnetizing is present only on one side of flexible holder?
Why in “iFixit 64 Bit Driver Kit” magnetizing is present only on one side of flexible holder? It is missing on side on which you attach selected bit, which makes them fall out when moved to more horizontal position.
Update (05/18/2020)
Below is image to show what I am exactly referring to:
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
This is what I am talking about. The head is aluminum. There is no magnetism on that side. If you need to, use an aftermarket bit magnetizer.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
If you are referring to the drive extension on the Pro Tech Toolkit, or the Mahi Driver kit, the end of the extension is aluminum (not magnetic). Push the bit into the extension all the way to hold it in place. If you need magnetism on the extension, use an aftermarket bit magnetizer, as pictured below.
Bewertung 1
I fell for this also I didn’t think of pushing it in until it clicked into place, it’s pretty obvious once it’s been pointed out but by then you’ve already revealed your/myself as an idiot🤪
Bewertung 0
Antwort hinzufügen
Tomasz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 47
Insgesamt: 850
