Zum Hauptinhalt wechseln
Das März 2015 Update von Apples 11" MacBook Air enthält Intel Core i5 und i7 Prozessoren der 5. Generation, was die Leistung und die Akkulaufzeit etwas verbessert.
140 Fragen Alle anzeigen
No power, MagSafe port smells burnt
I have a MacBook Air which failed to turn on, connected the charger and got a Green then Amber MagSafe light,
Connected my neighbors charger and still no power,
I attempted an SMC reset which made the charger go from amber to Green for a moment then back to Amber
After later removing the charger I smelled a plastic burning smell from the MagSafe port on the laptop.
If anyone knows how to fix it I would greatly appreciate it
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Lets give this a try, follow this guide to Step 3 MacBook Air 11" Anfang 2015 Akku tauschen. Now with nothing connected press the power button for a good 15 secs. Sit the system on its side so the MagSafe is on the top side carefully plug in the MagSafe charger, Did the system spontaneously boot up? If it did then you have a bad battery and will need to replace it.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Unfortunately I don’t have the screwdriver to remove the back but thank you for the advice
von
Here's the needed screw drivers:
P5 Pentalobe Screwdriver Retina MacBook Pro and Air
T5 Torx Screwdriver
And you needed this tool too!
Spudger
von
Antwort hinzufügen
will bevan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 180
