Zum Hauptinhalt wechseln
Die Xbox One S ist eine Entwicklung von Microsoft. Sie erschien im August 2016 als Neuauflage der Xbox One.
20 Fragen Alle anzeigen
when I press rt, my character moves forwards
When I press/hold the RT button, my character moves forwards which makes it really hard to play games like Overwatch.
I have a black powerA wired xbox one controller with LED’s on the rims, i forgot the actual name, please help
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
Same i have the exact same controller (spectre power A) and this also annoying when im playing minecraft have you managed to fix it i need help..?
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Hi!
Open up the controller and clean it from the inside. Also the input board.. I’m not sure how it looks like inside the PowerA controller, and I think it will be difficult to find replacement parts for that one too..
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
Thanks for the advice, but ive never really opened up a controller i will try though
Do i have to turn it off?
von
Your welcome! Yes, the controller needs to be turned off. The controller needs to be unplugged.
von
So all I need to do is open the controller and clean it? What parts should i clean, all of it?
von
Yes. Check for dust and remove it. The parts you should clean: Thumbsticks, input board (or ribbon circuit board).
von
what do i clean it with
Bewertung 0
1 Kommentar:
Alcohol wipes.
von
i have exactly the same controller and the same issue :(
Bewertung 0
These controllars can be a breeze to clean. You can find how-to-videos on YOUTUBE on how to clean or repair your model of controller. With a Power A You just need a precision screwdriver set, a bottle of isopropyl alcohol (aka Rubbing Alcohol), and some electronic cleaning swabs. And something to organize your screws. Some rubber mats are used for circuit boards and other assorted electronics and have little places to organize and keep your screws in place.
Bewertung 0
Antwort hinzufügen
H C wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 21
Insgesamt: 7,204
