Zum Hauptinhalt wechseln
Vierte iPad Generation, erhältlich seit dem 2. November 2012 mit 16, 32 oder 64 GB Speicherkapazität. Modellnummerb A1458.
218 Fragen Alle anzeigen
iTunes sees my iPad 4 but no display no life
Hello, when i plug in to a computer iTunes recognizes the iPad 4. I tried to check battery with multimeter, it’s ok. I tried to replace the lcd screen, it’s ok. I tried to recover and update, it’s ok. Is there any flowchart that i can follow to find what’s the fault? How can I go further and find the trouble? A technician told me that I was damaged the lcd screen. How to check if the screen is working or not?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Is this no backlight or no image? Shine a torch on the screen and see if you have an image.
von
Nothing, just deep black. But i can see on iTunes it's charging and fine, working. What to check on motherboard if I go advanced?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
How do you know that the LCD is ok? It sounds like a bad LCD and digitizer. I would try those first.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I bought a new lcd and replaced it very carefully. Now I have 2 screens in my hand but both of em doesn't working. Technician said that I was damaged the lcd's when i replace it. But i was very careful. Is there any way to check if lcd's working or not? Maybe with multimeter?
von
Antwort hinzufügen
Okan E wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 68
