Why is my screen flickering when the brightness is turned down?
Hello! I was hoping I could get some help with this. I recently purchased a Dell Latitude 7275 and noticed that the display seems to flicker when the brightness is turned all the way down.
(This is what it looks like: https://imgur.com/a/1bQYXpz It affects the entire screen, but is easiest to see on my wallpaper and on the cat.)
I'm not sure if this is a driver issue or a hardware issue. I've opened it up and checked the display cable and it seems ok, but I'll probably have to check again.
I've tried to update the graphics driver but I sometimes get a “Press F1/Volume Up to retry boot" message. In addition to this, checking the Intel Graphics 515 driver properties and looking at the “events" tab, it says that it's not completely installed. I'm not sure what's happening.
I should also note that I don't seem to have any sort of autobrightness setting, though I did go through the registry and try to disable anything that mentioned it.
I would really appreciate any help or advice you guys have. Thank you!
Ist dies eine gute Frage?
