Zum Hauptinhalt wechseln
Reparaturanleitungen und Informationen zur Demontage des MacBook Pro 16", das im November 2019 auf den Markt kam.
211 Fragen Alle anzeigen
Can’t boot in normal mode. Only Safe mode
Hi , I have a serious issue with my new MacBook Pro. It has 3 days. I was doing some stuff in bootcamp when it suddenly froze and the fans went on max, then it restarted. It started loading windows but did the same thing when booting up. I tried to get it to MacOS but the loading bar went to 3/4 and it crashed. I tried resetting the NVRAM and SMC, i also re-installed the MacOS, but that didn’t work. I then erased the whole drive including the bootcamp partition and everything, re-installed MacOS again, but that didn’t work.
also!! The MacBook loads without any issues to Safe Mode. Please help me!! I’m already crying over it. It has 3 days!
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
Same issue here, it seems a pretty common problem with MBP 16. It is related to a GPU issue. Most of the people fixed it with HW repair, still trying to get mine fixed through Apple Care.
von
Einen Kommentar hinzufügen
1 Antwort
Call Apple Support to set up an appointment for you at an Apple Store to have them help you. Re-installing your OS should have worked, I’m suspecting you have a deeper issue here.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Jacob markowsko wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 273
