Replacing the USB-c charging port
I have a problem with my iPad Pro 12.9 3rd gen.
The iPad suddenly stopped charging, but - if connected to the MacBook - it still exchanges data, it sychronizes (at least id did it, since now the battery is completely out of juice) without charging.
Apple told me that it might be a problem with the usb-c charging port. I receive a couple of quotes the are ridiculous (about $530 dollars). I am starting thinking I can replace the USB -c charging connector by myself. Do you have any advice on that?
thanks everybody!
Ist dies eine gute Frage?
1 Kommentar
I just completed this repair on my wife's iPad pro 12.9". Her iPad stopped charging when connected to any one of our chargers or cables, so I figured it was worth trying. You may cringe, but ai had an accurate thermometer and a large pancake griddle. I set the dial so the griddle reached 135 degrees, and set the iPad on it screen up for 10 minutes. The LCD glue got very soft and I was able to carefully break the glue seal with an iFixit metal spudger and some guitar picks. That was the hard part. While working around don't go deeper than 1/8th inch or you can damage cables. I did not remove any of the screen cables and instead replaced the port with them remaining connected. I then tested the iPad, then removed the old adhesive and applied new, tested again, then stuck the LCD back down. We had to retrain face ID, not sure why.
von Jim D.
