GE Profile Microwave is blowing through door switches
I have a Profile microwave that’s about 10 years old. A couple of years ago it stopped working, and the problem turned out to be the door switch. (Surprise!) I replaced the switch, and everything was fine for about 6 months. They it stopped working again. Door switch again. Fixed. Good for about 6 months. Dead switch again. What’s going on?
I see two likely causes. 1) I’m buying $5 switches off Amazon instead of the $40 OEM switches from Sears Parts Direct. 2) There’s an issue with the microwave that’s causing it to melt switches. And melted they are. The bottom lead is consistently melting the plastic that supports it, leaving it twisted at a 45 degree angle. And it’s always the same switch.
Occam’s Razor says it’s that the switches are cheap, but before I go spend $40 for a tiny, unispired bit of plastic and metal, I thought it was worth asking the question. Anyone have experience with cheap switches dying or microwaves killing their switches repeatedly?
Ist dies eine gute Frage?
3 Kommentare
Did you ever get this figured out? I am having a similar problem with a Kenmore elite over the range. Exhaust fan and lights work but it keeps blowing out the middle microswitch. I replaced the worn plastic holder for the microswitch but it still fails. So frustrating!
von Scott
I've had this problem, and discovered that it has to do with door alignment or switch alignment being off. And it only happen when I open the door while the microwave is running. If I do, the switches don't switch at the same time, and the one gets welded together and trips the breaker. If I turn the microwave off before opening the door, it's fine, and the switches keep working. More info here: https://appliancerepairforum.com/PrintTo...
von Beerhistory
Consider replacing the door latch assembly. Also called the door hook. It will wear over time and not properly engage the switches. These cost from $10-$25 on Amazon. Also, do not open the door while the unit is running. Let it stop on its own or hit cancel. This is one major reason for switch failure.
von Jay E
