Zum Hauptinhalt wechseln
2,5 GHz Dual-Core Intel Core i5 Prozessor (Turbo Boost bis zu 3,1 GHz) mit 3 MB geteiltem L3 Cache.
264 Fragen Alle anzeigen
How do I fix colored lines down my screen caused by pressure?
My laptop was open and I had been using it. I went to push the screen back a little and placed my hand around the side of the screen (so my thumb was on the screen and the rest of my hand was on the back (in picture). Suddenly a bunch of lines popped up tracing to where my thumb was and have not gone away in weeks. The glass itself is not broken so I think the issue is underneath. Is this fixable? How expensive would it be to fix?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Same thing happened to my school computer I don't think you can fix it yourself they are taking mine to get fixed and its gonna be 550 dollars
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Sorry to tell you the back glass (LCD panel) is cracked!
I often see this happen when something like a pen or pencil was resting on the keyboard and the lid was closed on it.
You’ll need a new display assembly 13” Retina MacBook Pro Display Assembly, Apple P/N 661-7014 and here’s the guide you’ll need to follow MacBook Pro (13 Zoll, Ende 2012, Retina Display) Displayeinheit austauschen
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Thank you so much!
von
My brother has an old Macbook Pro from early 2011 (the one that still had the disk drive) but it is very slow . Can I take his LCD screen and put it in my Retina Macbook Pro
von
@sabrinabruno3 - Sadly, you can't use your brothers system for parts. There is too many differences for it to work.
Just like cars which look alike from the outside one uses gasoline and the other uses diesel! All you'll do is damage the engine if you put in the wrong fuel into the wrong car!
von
Antwort hinzufügen
Sabrina Bruno wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 23
Letzte 7 Tage: 135
Letzte 30 Tage: 515
Insgesamt: 12,371
