Zum Hauptinhalt wechseln
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K Display. Benutze die Anleitungen des iMac Intel 27" Retina 5K Display (Ende 2014 & 2015), da das Gerät sehr ähnlich ist.
293 Fragen Alle anzeigen
Forgot to split Fusion Drive
Recently I replaced the 1 TB hard drive with a 1 TB SSD and forgot to split the fusion drive. Since I already paired the old SSD to the new SSD I cant simply reconnect the old drive. I plugged the old hard drive into another computer i have and the drive wont mount. Is there anyway to get the data off the hard drive?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
First setting up a dual SSD Fusion Drive really doesn’t improve performance! Depending on the size of the blade SSD its best to just setup a dual drive config with the blade SSD setup as the OS and App drive. If you have a small Fusion Drive SSD (128 GB or smaller) then its best just to leave it unused.
As far as recovering your files from the original HDD if you’ve installed anything higher than High Sierra (likely here) then your drive is setup with APFS file system so older HFS+ drive & file recovery tools are useless! Apple has not offered the drive/file recovery folks the means to recover drives or files under APFS.
As you’ve over written the cache drive (blade SSD) the keys are gone!
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
So basically I would need to pay for a data recovery if I want to get stuff off the old drive?
von
I don't think they can do it either ;-{
von
Antwort hinzufügen
Naitsa wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 206
