Zum Hauptinhalt wechseln
Modell A1312 / Mitte 2010 / 3.2 GHz Core i3 oder 2.8 & 3.6 GHz Core i5 oder 2.93 GHz Core i7, ID iMac11,3
382 Fragen Alle anzeigen
White screen at boot
Every now and then, i get a white screen, that seems to cover up the users login page. This occurs just before the Apple logo and the Chime sound. Normally when this occurs, thinking that its a freeze, i do a restart by using the power button. But today i acted as if there was no white screen and i pressed the buttons as if i was logging in to my user and it worked. This white screen seemed as if it was a cover up.
What could be wrong? Is there anything i can do about it? Any suggestions?
Update (08/24/2020)
I noticed that i can log in despite the whitish screen i see at boot. I have 2 users, one is a guest and the other is admin. Entering the admin user without seeing is not so easy, but entering the guest can be done with closed eyes since i can enter it simply by pressing enter on the withish screen. Apparently logging in works even if i cant see the screen.
So i enter the guest and then i log out and enter the admin and it all works fine. Isnt that strange? Maybe just maybe might this be something else?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The white screen indicative of a failing GPU board! iMac Intel 27" EMC 2309 oder 2374 Grafikkarte Austausch
War diese Antwort hilfreich?
Bewertung 1
10 Kommentare:
Is there a way (an applications perhaps) that i could know at what state of functionality the graphics card is?
von
Your system originally came with either a ATI (AMD) Radeon HD 5670 or Radeon HD 5750 graphics MXM board.
To find out go to About This Mac > System Report click on Graphics/Displays section you should see two graphic services the built-in Intel and the MXM board.
von
Dan, i was thinking... if it was a failing GPUboard, should i have graphic issues in other cases as im working? Why does this happen only at boot, and why if i reboot it works fine? Are there any answers to these questions? Just wondering :-)
von
Thats the difference between Failing and Failed ;-}
von
I guess in my mind... "failing" is continuous procedure of partial failure until it reaches the "failed point" of no return.
What i want to ask, which is important is... How can i see my files if the board reaches to the point of no return and the iMac although it boots i cannot see the contents. Is there a way i can see my desktop and manage my files for a short period of time until i migrate them to a diff computer?
von
5 weitere Kommentare anzeigen
Antwort hinzufügen
genik wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 231
