Zum Hauptinhalt wechseln
Der K-Gro Power Pro Handrasenmäher, hergestellt von der Modern Tool and Die Company.
Need front and rear wheels. Model RBSP205A
Need front and rear wheels for my lawnmower
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
After searching for it a little bit I couldn’t find any spare wheels for your model.
If I understand you correctly, you are planning to replace all four wheels, so it would work if you get any wheels that have the same mountings and are about the same size as the old ones (just measure so they are big enough so the body isn’t laying on the ground and small enough to fit).
If you add pictures and measurements for the mounts and the size of the wheels, then someone may be able to found some that fit. Bilder zu einer vorhandenen Frage hinzufügen
War diese Antwort hilfreich?
Bewertung 0
Hi @garage45
Here’s a link to the parts diagrams for your model.
Click on the rbsp205a.o1 link to get the parts diagram that shows the rear wheels with flange lock nut and hub cap
Click on Index numbers 37, 38 & 40 and then click on Process Choices, to get the prices and the part numbers for the parts. If you search online using the part number only for the wheel and the flange nut, you will get results for other suppliers for these two components, that may suit you better. This method didn’t work to find any other suppliers for the hub cap though
Click on the rbsp205a.o3 link to get the parts diagram that shows the front wheels with flange lock nut and hub cap
Click on Index numbers 27, 28 & 30 and then click on Process Choices, to get the prices and the part numbers for the parts. If you search online using the part number only for the wheel and the flange nut, you will get results for other suppliers for these two components, that may suit you better. This method also didn’t work to find any other suppliers for this hub cap either
Bewertung 0
Antwort hinzufügen
Sharon3 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 469
