Zum Hauptinhalt wechseln
Dokumentation und Anleitungen für die Reparatur des am 22. September 2017 veröffentlichten iPhone 8. Modellnummern A1863, A1905.
32 Fragen Alle anzeigen
iPhone 8 bottom speaker not working
Hey guys, I have a phone repair lab and recently someone came with an iphone 8 that the bottom speaker isnt working, but the top one does work. ive tried replacing the speaker, replacing the chargin port, even changed his audio ic and nothing seems to work. maybe someone knows why is this happening?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Firstly it is always good to know the history of the phone especially when it comes to audio problems.
·         What was the phone doing before the sound stopped?
You should have left the audio IC alone as you have just created a variable in your repair. The audio IC decodes and encodes the sound, since you said top speaker was working I would be looking at the speaker amp components.
You need to diode the dock connector there are filters near it that could have been nudged or blown. Check for open lines on the speaker amp circuit. If you have ruled out parts that is where the problem should be.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Yeah i saw what youre saying, i replace thsoe filters and the bottom firing speaker worked for half a seocnd and then stopped wokring again.
von
Antwort hinzufügen
Digital Post Eilat שיקוט wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 564
