Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s Plus gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
1041 Fragen Alle anzeigen
Removing WiFi ic chip on motherboard
Hi guys quick question
ive been looking on YouTube about the WiFi chip on the 6s plus. Some show the chip needs to be programmed and some doesn’t show it. My issue is the WiFi isn’t working. The repair guy also mentioned about programming. Just wanted to know if that had to be done. Thanks
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
The Wi-Fi chip needs to be unbinded. I usually do this by removing the NAND which is where the information is stored and reprogramming it to unbind the Wi-Fi serial number. There are other programmers out there that claim to accomplish this without removing the NAND but I cannot comment on those as I have never used one.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Yes because one of my repairers are telling me they can do it without programming and the other said they need to reprogram the chip. I don’t know which one I should for? Anyone else have any input to this.
von
You don’t need to program the chip. You just need to un-bind the old ones serial number from the NAND and it will automatically write the new serial number when booted.
von
Okay so if I was to get a new WiFi chip and solder it to the board. It will just. Automatically read the serial. Also how I’ll I go about unbind img th old serial number?
von
Antwort hinzufügen
Rakesh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 589
