Zum Hauptinhalt wechseln
The Ford Expedition is a full-size SUV assembled by the American automaker Ford Motor Company. Introduced as the four-door successor of the two-door Ford Bronco, the Expedition has remained in production since the 1997 model year; it is currently in its third model generation.
77 Fragen Alle anzeigen
2006 expedition king ranch 5.4. 3 valve
Was having problems with misfires I replaced the spark plugs and all the coils and cleaned the throttle body now I’m in Failsafe mode it’s got 7 codes now cam sensor both sides ,mass air , o2 sensor both sides upper , throttle what do I do now
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
What spark plugs did you use? Brand and model?
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
motorcraft plugs
von
fail safe code came on truck will not start
von
Make sure you use the same spark plugs that came from the factory. It can cause run problems with the wrong plugs. Make sure you have the correct plugs and erase the trouble codes and see if it will start. If it starts see what codes come up. If it doesn't start see what codes come up. Message me back with the codes and let me know if it started or not.
von
Antwort hinzufügen
john Distasio wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 51
