Zum Hauptinhalt wechseln
Die Neuauflage des Apple 13" MacBook Air von April 2014 wurde mit Dual-Core i5 und i7 Prozessoren aufgefrischt. Die Akkulaufzeit wurde etwas verbessert.
313 Fragen Alle anzeigen
Laptop Dies When Unplugged
Hello all, first time here.
Recently inherited this MacBook from my dad who hasn’t used it in a year. The battery does not keep a charge and the laptop can only run on the power adapter. The MagSafe stays a constant orange. I have reset the PRAM and SMC and ran the hardware diagnostics which says everything is normal. Power report is as follows:
Battery Information:
  • Model Information:
    • Serial Number: C0142270EFVF90MA5
    • Manufacturer: DP
    • Device Name: bq20z451
    • Pack Lot Code: 0
    • PCB Lot Code: 0
    • Firmware Version: 511
    • Hardware Revision: 000a
    • Cell Revision: 1200
  • Charge Information:
    • Charge Remaining (mAh): 839
    • Fully Charged: No
    • Charging: No
    • Full Charge Capacity (mAh): 6018
  • Health Information:
    • Cycle Count: 105
    • Condition: Normal
    • Battery Installed: Yes
    • Amperage (mA): 11
    • Voltage (mV): 7395
It seems like the cycle count of 105 is well within its expected lifetime but I suspect the year with no use could have destroyed the battery. Anyways. not sure why there is a small amperage but it says it is not charging at all. I would bring the laptop to the Genius Bar or a service center but few places are open with COVID19 right now.
I’m willing to replace the battery myself if it seems that is the solution.
Thank you in advance for any guidance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Yes you need a new battery, here’s the needed part MacBook Air 13" (Late 2010-2017) Battery and here’s the guide MacBook Air 13" Anfang 2014 Akku austauschen
MacBook Air 13" (Late 2010-2017) Battery Bild
Produkt
$69.99
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thank you! Just finished charging the battery after the install and I'm following the calibration steps! Everything looking good.
von
Hilfreichste Antwort
you need a new battery.
Bewertung 1
1 Kommentar:
probably need a new battery
von
Antwort hinzufügen
mbelle wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 188
