Zum Hauptinhalt wechseln
The Asus VivoBook S400C is a touchscreen laptop released in October 2012. This model is identified by a sticker on the bottom of the device as “ASUS S400C Notebook PC”.
2 Fragen Alle anzeigen
How do you remove this kind of Laptop LCD connector
Guys I have a Asus Vivobook X411UN and I'm trying to replace the LCD. But the problem is I don't know how to remove laptop LCD connector pin.
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Hi,
Post a close up image of the connector
Bilder zu einer vorhandenen Frage hinzufügen
von
Done posting
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
@razankasglen
Don't know the answer so hopefully someone else will.
Perhaps if no one else answers, since you have to replace the LCD screen then maybe just disconnect the cable from the LCD screen end only and connect the new screen to it.
Looking at the replacement cable it seems that it can be removed from the LCD and is not permanently connected to the display assembly as some are.
Perhaps it may be easier to get at.
The part number for the cable is 14005-02440100 found on this website
War diese Antwort hilfreich?
Bewertung 2
Thanks for the picture. There are two shoulders on the cable connector that provide a place to push on to remove the connector. I'm assuming it's similar to the one used on the S400C in that being taped down it almost certainly doesn't have any kind of latch.
Take a couple of spudgers and place one at each point of the arrow and push them both evenly in the direction of the arrows. It should simply slide out - it may take a little bit of force; I know the S400C does.
Bewertung 1
Just pull the sticker to the point shown in the image,
Then pull out the lego type connecter little by little, by pulling left and right side of the connecter little by
Bewertung 0
Antwort hinzufügen
razankasglen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 57
Insgesamt: 2,120
