Zum Hauptinhalt wechseln
Veröffentlicht im Juni 2009 / 2.66, 2.8 oder 3.06 GHz Core 2 Duo Prozessor
300 Fragen Alle anzeigen
Any side effects of operating thelaptop without a battery?
This Macbook Pro was given to me sans battery. Has a fractured LCD support frame but it works. I propped up the LCD lid on a plastic jig. The thing works but given its state, I use it running on power adaptor only. The date of course has to be reset everytime I power on. Aside from this minor inconvenience, are there any side effects I should know? I seem to recall that the Intel processor won’t run at full speed, but the thing runs fast enough for me.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Your charger is not able to support your system when your apps need full CPU & GPU performance. Your system will conk-out corrupting your drive!
I strongly recommend you property fix your system. As this is in a fragile state both physically and data wise (corrupted drive)
A common issue in this series is the back shell becomes unglued to the lids mid frame and in some cases the frame its self cracks when in this state, It’s worth the gamble to fix the lid. Follow this guide to take the LCD panel out MacBook Pro (15 Zoll, Mitte 2009, Unibody) LCD austauschen
And get a new battery! MacBook Pro 15" Unibody (Mid 2009-Mid 2010) Battery
For the investment of 100 bucks this is worth it! Even if you only use it for a year or two waiting to see what Apple is upto with the coming Apple Silicon systems.
MacBook Pro 15" Unibody (Mid 2009-Mid 2010) Battery Bild
Produkt
$89.99
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
i mean, you wont have a battery, thats probably it besides if ur power goes out ur done, along with if someone trips over it
Bewertung 1
Antwort hinzufügen
Bernie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 60
